5655 Swipe Card for Admin?
  • mrfuser
    • 1605
    Client just purchased this machine and it works fine, but when we try to go into admin it says SWIPE CARD and in the upper right it says KEYBOARD ACCESS. Is there a way around this to shut it off? If we hit KEYBOARD ACCESS it just processes for a bit then defaults back without doing anything.
    If we reset Network NVM will this cure this problem?
    Kelly
  • Exok
    • Jun 2011
    • 750
    Re: 5655 Swipe Card for Admin?
    Do a full NVM reset. On this machine the only thing you really need to preform after a full NVM reset is the registration adjustment (very simple and quick).
    • mrfuser
      • 1605
      Did the NVM reset, no change. Still asking to swipe card and won't let me into admin mode at UI.
      Kelly
      • adriansto
        • 2383
        As I said you on pm you must do software reload. When secure acces with usb card reader is enable this is the method to bypass machine security.
        • mrfuser
          • 1605
          Do I need a pws to do so?
          • adriansto
            • 2383
            Machine has a builtin net controller or is a external box controller situated at low rear side of the machine ?
            • mrfuser
              • 1605
              Built in and tcp ip or any protocols are not active so we can't see it on web interface.
              • adriansto
                • 2383
                That means machine is SBC. Perhaps you dont need pws for reload software. Only proper software.
                What actual software version is on copier ?
                • mrfuser
                  • 1605
                  025.054.039.00000
                  How do I reload if everything is disabled such as USB and tcp/ip?
                  • adriansto
                    • 2383
                    025.054.039.00000
                    How do you know usb is disabled ? Can you post config report from machine ?
                    • mrfuser
                      • 1605
                      Not sure you can read it but it says
                      usb port enabled: Disabled
                      • adriansto
                        • 2383
                        That is fine ! You cannot print to usb printer port but you can connect with admin software tool.
                        Also there are two A type usb ports and you can use these ports for reload software.
                        • mrfuser
                          • 1605
                          Okay, so I just copy the system software onto a USB stick then plug it into one of the USB ports on the back and turn copier on? Is that the correct procedure?
                          Kelly
                          • adriansto
                            • 2383
                            Aproximate ! Read the service manual.
                            • mrfuser
                              • 1605
                              Okay, went to get PWS and I can't get it to connect to PWS or altboot using 8 key. Machine shows no errors and copies just fine. Whats the deal on this beast?
                              Kelly
