4110 blank screen
  • denden4h
    • Mar 2006
    • 31
    [Dead] 4110 blank screen
    I need some help on this one. Installed a Hear Roller kit. Unit started jamming in finisher. Initialize finisher in pws, tray 7 starts behaving like the lift motor has gone bad. Use restore to load last settings from previous visit, unit gives 116-331 code. Follow procedure to re-install hdd, now unit has blank screen but motors and clutches are turning on properly. Can't get pws to connect. Need help badly, this is customer's big gun unit. Thanks.
  • dorez
    • Feb 2013
    • 73
    Re: 4110 blank screen
    from what i am reading from error code 116-331 you did everything but, however also says replace the ESS PWB. I hope this helps
    • Exok
      • Jun 2011
      • 750
      Holy cow!! Don't replace any more heat roller kits!! You're doing it wrong!!
      My first question is: Aside from the heat roller being worn, did you have any strange problems before replacing the heat roller?
      If no, go back and check the fusing unit for pinched wires.
      • denden4h
        • Mar 2006
        • 31
        Reseated connectors and chips on ESS, MCU, AC & DC boards. Screen started coming on with white screen, but I was able to connect pws and re-initialize the unit. So far everything is OK except a recurring issue with the Finisher (fault code 012-159). Have previously posted on this one and have done everything. I believe the system software (firmware) might be the issue. If anyone has it, it would be appreciated.
        • adriansto
          • 2383
          What sw version is on the machine ?
          For the 2.1 sw version exist a little patch that may be fix this error code.
