Hi. I've got a problem on the above machine. The machine prints fine, but when you try to scan or copy(through adf or platen glass) nothing happens. It sometimes says copying but then just sits there doing nothing. Is it possibly a scanner problem?ive powered off and on, also disconnected and reconnected the add and scanner. No experience on this machine so your help would be very much appreciated.
thanks
thanks
