WC 255
  • denden4h
    • Mar 2006
    • 31
    [Dead] WC 255
    Working on this unit that has a jam indication in areas 3 and 4 and it won't clear. I have checked and reseated all sensors in the paper path and checked the connector for the fuser. I can't connect to pws. Any advice on this issue would be appreciated.
  • NormMet
    Re: WC 255
    Did you figure it out?
    Usually jams in area 3/4 are Jams in the fuser itself (there's a fuser exit sensor that can get broken).
    Another culprit is the iot exit sensor sticks, the plastis on the inverter assy warps causing a false error.
    Another sensor is the duplex sensor, it can get mangled. I've straightened them out instead of replacing them.
    • denden4h
      • Mar 2006
      • 31
      Re: WC 255
      Turns out something was wrong with the fuser. Installed one and it's back up and running. Thanks for all your input.
