Docucolor 252 yellow streak
  • fatfingers73
    • Feb 2013
    • 219
    [CQ] Docucolor 252 yellow streak
    Anyone come across this before?
    Tried swapping drums and dev tanks but still getting thick yellow band across top of copies/prints.
    Machine has recently been relocated and was fine before the move.
    The yellow band is on the rear of the transfer belt when I pull it out.
    Cleaned all ros windows.
    Any advice would be appreciated.
    Thanks.
  • fatfingers73
    • Feb 2013
    • 219
    Re: Docucolor 252 yellow streak
    Anyone?
    Need some ideas before I return.
    Thanks.
    • bojans
      • 1313
      I had something like that with cyan and it was ROS.
      • fatfingers73
        • Feb 2013
        • 219
        Hi, thanks for the reply. Wouldn't a dirty ros window just cause blank lines in prints?
        The machine was recently moved 500 miles with toners left in.
        I gave the ros windows a quick wipe, I didn't spend too much time on them because I didn't think it could cause the wide yellow band.
        Cheers.
        • bojans
          • 1313
          I didn't mean it was dirty, But it was faulty . Try replacing ROS assy.
          • fatfingers73
            • Feb 2013
            • 219
            • bojans
              • 1313
              There are two ROS units, one with K and C, and other with Y and M.
              I'm not sure if you could interchange those two units just to be sure if there is a problem.
              It's not too complicated to reach ROS, follow the documentation. But those flat cables could be pain in the ass sometimes.
              • fatfingers73
                • Feb 2013
                • 219
                Oh OK thanks. They're different part numbers so probably can't be swapped.
                Thanks for your help.
                • bojans
                  • 1313
                  You're welcome
                  • adriansto
                    • 2392
                    You can cover the ros window with black paper strip and see if the band appear again.
                    I will look at the position of yellow drum and yellow dev. assy
                    • fatfingers73
                      • Feb 2013
                      • 219
                      Thanks for the advice.
                      Yellow drum and dev looked good.
                      Client has ordered new ros assembly. What's the easiest way to ensure it is the ros before I open the new unit?
                      Kind regards.
                      • adriansto
                        • 2392
                        Kind regards.
                        As I said, cover the yellow ros window and do same print test. If the Y band is still on the paper the ros unit is good. If theY band disappear then may be the ros unit is defective. Print from service menu yellow print tests at 10%, 20%, 30%, 50% coverage. If all the test prints are uniform then again the ros is good
                        • WIWA
                          • Mar 2009
                          • 97
                          hey its looks like bad drum ,just try another drum ,switch cyan or magenta if their good . or maybe a lose internal lens inside ros assy.
                          Hope this help
                          Wiwa 72
                          Gonzos build v 1.0
                          • fatfingers73
                            • Feb 2013
                            • 219
                            Thanks, already tried switching drums.
                            Going back tonight to fit new ros assembly. Will update thread later.
                            Cheers.
                            Hope this help
                            Wiwa 72
                            Gonzos build v 1.0
                            • fatfingers73
                              • Feb 2013
                              • 219
                              Update:
                              Fitted new yellow ros and everything looked good for around 50 copies/prints.
                              Then yellow band started to return, it now comes and goes!
                              It's driving me mad! Any advice would be great
                              When the fault is there yellow is missing from the print apart from the 1-2 inch band at the top of the sheet. It's like it's squashing all the yellow to the top of the sheet.
                              I've never had this before on any brand of machine.
                              Less importantly there are three little marks on each copy/print around 19cm apart. They're there on colour, mono and single colour (always black marks). They're not coming from drums or transfer belt?
                              Ideas please? Thank you.
