Xerox c2636 RegiCon fail DC685
  • Tinochka
    • Jul 2012
    • 127
    [CQ] Xerox c2636 RegiCon fail DC685
    I faced the problem. Color missregistration on xerox c2636. I tried to do RegiCon setup (DC685), but fail.
    Some times there is a 04-341 error code
  • Tinochka
    • Jul 2012
    • 127
    Finaly I found the cause the problem!
    I connected another controller and nvm mcu, after that all worked fine!!!
    I think I need to reinstall system software.
    Picture1 from old controller configuration report (it doesn't work)
    Picture2 from another controller (works fine!!)
    But I have only 04.520 and don't have 04.522
    Does anyone has problems with version 04.520 ?
    Thanks!
    • Tinochka
      • Jul 2012
      • 127
      Re: Xerox c2636 RegiCon fail DC685
      An image disk was damaged, and I disconnect it earlier. Every thing was ok. But I didn't try regicon procedure.
      Now when I need regicon procedure, it was fail.
      Now I connect image disk and regicon procedure is ok!!!!
      I hope it will be usefull for somebody.
