9-383 xerox 2636
  • Tinochka
    • Jul 2012
    • 127
    [CQ] 9-383 xerox 2636
    Hi.
    Can anybody look at eureka about this code?
    I don't have one for xerox 2636.
  • livewire
    • Sep 2011
    • 608
    Re: 9-383 xerox 2636
    It's about WorkCentrePro C2636, right?
    What is this, Xerox 2636?
    9-383 applies to Black Drum Cartridge.
    Replace drum and reset the NVM for this fault.
    • xcopytech
      • Aug 2006
      • 1793
      09.383, 09-548 Black ATC Sensor
      The Black ATC Sensor detects an insufficient amount of developer material
      Check black developer assy.
      You need WCPS diagnostic navigator to reset this code.
      • Tinochka
        • Jul 2012
        • 127
        Thank you
        I read some of that information in doc.
        But I would like to have some information from eureka. Probably somebody had the same fault code but the cause of the problem was different.
        I check the developer material, reseted the fault code, but nothing helps.
        When I connect to mashine via diagnostic navigator, I dont see information about supplies (toners, drums...) I can see only 0%
        So I think the cause of my problem is different than described in doc. That is why I need some informations from Eureka.
        Thanks.
        P.S. The customer says, there were some prints outs covered with black toner.
        • zeeeba
          • Dec 2012
          • 58
          PM me I have some information.
