xerox w/c 5855 scan... goes blurry
+ More Options
Posts
  • landspeeder
    • Feb 2010
    • 355
    When the client is scanning to a P/C or making copies, thru the dadf, the scans or copies become blurry...like not using glasses to read when you need them......if they shut the machine off and then power up its fine for a while then becomes blurry again...any ideas? The ser. manual doesnt say anything and the error log doesnt have any errors except for some paper jams
    You never realize how cheap a professional is until after you let an amateur do it.... and
    if this was an easy thing to do then everybody would be doing it! But it isn't and they are not!!
  • Exok
    • Jun 2011
    • 750
    Re: xerox w/c 5855 scan... goes blurry
    My first guess would be something mechanical with the scanner. Possibly a loose or miss-positioned mirror. Maybe dirt build up on the scan rails is causing jitter. Does the problem differ between ADF and glass scanning? If its only with the ADF, maybe there is too much space between the original and the scan glass. If the original is not against the glass you can get the type of CQ problem you described.
    • landspeeder
      • Feb 2010
      • 355
      Morning!
      If it was mech. would power off/on fix it for a while? Unless by doing this it goes to a home position on power up and then slowly creaps away from home. They never do the glass scan so they dont know and since it is a on/off problem they dont want to stand there and watch.... anyways its a out of focus situation like a camera which in a way it is the same thing...so what controls the focus on a scan....if it was a DADF clearance issue then the po/po wouldnt help that...sigh...thanks for your help by the way...also do you have a firmware update as the xerox site shows last march/13 as most current...firmware can be a help also
        • 22997
        Is the resulting image compressed or stretched? Perhaps you've got a document feeder motor speed problem. If yes, it would never have a problem from the glass. =^..^=
        • landspeeder
          • Feb 2010
          • 355
          Nope just blurry...out of focus....not comp or stretched... thks
          • adriansto
            • 2383
            WorkCentre_5845-5890_system-sw07119010335100 is the last version.
            But you must check if the scan from platen is good.
            Defocusing problem is not a software problem.
            • landspeeder
              • Feb 2010
              • 355
              Have you seen de-focusing and what was the cause....what if I email you a sample.... also can I get the firmware update from you...would N/A version be different from Europe
              • adriansto
                • 2383
                stoadis@gmail.com for sample.
                The firmware is for all markets
                • landspeeder
                  • Feb 2010
                  • 355
                  I will send tomorrow...also can I get the firmware from you ours seems to be outa date...thanks
                  • adriansto
                    • 2383
                    Will talk tomorrow on mail
