Xerox 5745
  • big mike
    • Sep 2012
    • 155
    [Dead] Xerox 5745
    I rendered a perfectly good Xerox 5745 copier totally useless and need some help. I was trying to setup the fax through the touch screen (UI) and was playing around...accidentally entered DC305, UI screen calibration. I didn't read the micro font prompt which has you press 9 'different points' on the screen. Once you start, there isn't a cancel prompt. I missed half the points and it finished and rebooted. Now the screen is WAY off, can't log in with admin, 1111, can't do anything.
    It will copy and print fine as long as you don't touch the screen.
    I could maybe reload 61.132 sw through the browser. It didn't come with the MRDisk so I can't reload sw. I have the pdf manual, but DC305 doesn't have an answer if it fails. I could buy another copier for parts...any ideas?
  • adriansto
    • 2387
    Re: Xerox 5745
    There is a pws software tool for this machine. With this tool you can do a NVM Init but only if the USB type B printer port is in to correct status. Do you have an configuration report from machine ?
    • Flash
      • 378
      Re: Xerox 5745
      Press and hold * and # buttons then release at the same time
      Press the * button to access UI calibration
      Press P1,P2,P3,etc., press the point where the lines intersect
      • big mike
        • Sep 2012
        • 155
        Re: Xerox 5745
        Thanks! I'll try it today.
        • big mike
          • Sep 2012
          • 155
          Re: Xerox 5745
          I have pws software for the 56XX series but not for the 57XX products. I'll check the config. sheet. Do you know where I can get the 57XX pws sw? i can send you my email or cell.
          • big mike
            • Sep 2012
            • 155
            Re: Xerox 5745
            That did not work. Is there anything else you could suggest? Let me know and I'll try it.
            Mike
            • adriansto
              • 2387
              Re: Xerox 5745
              Send mail at stoadis@gmail.com
