Xerox workcentre pro 275 copy problem
  • Tropix
    • Jul 2011
    • 45
    [CQ] Xerox workcentre pro 275 copy problem
    I have problem with copy on xerox workcentre pro 275, half A4 copy is black lines, on print all is ok
    i replace scan carriage assy but no help, any suggestion is welcome
  • WIWA
    • Mar 2009
    • 97
    Re: Xerox workcentre pro 275 copy problem
    Wow it sound to me the eyes (CCD assy.) or the image processor pwba a bad memory. if prints ok as you said check out the machine eyes.
    hope this help
    Wiwa 72,
    Gonzos build v.1.0
    http://www.docdroid.net/9a06/275-problem.pdf.html
    • adriansto
      • 2384
      Copy from dadf and from platen glass have same dark band ?
      • Tropix
        • Jul 2011
        • 45
        yes same from dadf and platen glass
        this scanner is not same on 245 or 5655 etc....here is ccd and lamp on scan carriage.....
        • adriansto
          • 2384
          Yes, I know the machine, but still there a flexible cable from scan carriage to scan pwb. Also a cable for lamp.
          • Tropix
            • Jul 2011
            • 45
            I checked that the flexible cable with the measurer and the pins are Ok. Do not know if it is possible to break when flexes and creates these lines on copy ... whether to order it cable and PWB ?
            • adriansto
              • 2384
              Before starting replacing the electronic boards= pwb's, try to replace the cables and clean the contacts. if also you can try to change the ends of the cable from probing if is something wrong when it flex.
              You can use cables from another working machine. Foorv findr pwb you need to order it at Xerox dealer from your region, ebay or find a second hand machine.
              • scenicmike
                • Feb 2014
                • 13
                It is definetely the flat cable from lamp carriage to scan pwb!
