5638 system unavailable
  • mrfuser
    • 1605
    Got a 5638 that won't boot. Replaced power supply and removed controller with same result. Any thoughts?
  • blackbooger
    • May 2012
    • 12
    Wont boot as far as what? How far does it get?
    • xcopytech
      • Aug 2006
      • 1792
      Re: 5638 system unavailable
      measure voltage on software module battery
      • mrfuser
        • 1605
        It boots as far as it says:
        System Unavailable. .....
        Then says to power down and try again.
        • xcopytech
          • Aug 2006
          • 1792
          remove software module and mesure voltage on battery.
          if voltage is below 2.8v then you need to replace battery and to restore machine configuration from machine diskette
