Xerox 7830 Breaker switch tripping
  • ATurner123
    • Aug 2025
    [Dead] Xerox 7830 Breaker switch tripping
    Hi, I have a xerox WC 7830 that keeps tripping the GFI breaker switch on the rear intermittley. Firmware has been upgraded. I'm going down the road of replacing the main LVPS on the device. Has anyone had this problem or simular, Any info would be great. Thanks
  • InterfaceP
    • Jun 2013
    • 488
    Re: Xerox 7830 Breaker switch tripping
    What is the required amperage for the 7830?
    How may amps are coming out of the wall? Look at the breaker panel and verify the amps (#on the switch) isn't higher than that required by the printer.
    • ATurner123
      Plug and socket have both been checked, 13 Amp fuse replaced, different socket also used. Still trips every 3/4 hrs.
      Cheers
