Dc 12 Prints Bad Help
+ More Options
Posts
  • artdigital
    • Aug 2025
    I HAVE A BIG PROBLEM. MI DC 12 WAS WORKING GREAT UNTILL IT PRINTS VERY BAD, PLEASE SOMEBODY HELP ME.
  • deep
    • Jun 2008
    • 208
    The surface of the copy seems touching something when it goes to the fuser.
    Kenny
    • Veedle
      Xerox Tech
      • Jul 2008
      • 44
      It looks like you have a problem with your fuser. Check the condition of the oiler and your fusing pressure first.
      Does it do the same effect on normal - uncoated paper ?
      If it doesn't you will have to replace the oiler assembly and the fuser roller then setup the fusing pressure evenly.
      • TechMate
        • Mar 2008
        • 285
        Check the condition of the fuser unit where these components might be causing the problem:
        1. oil donor and distribution assembly
        2. heat roller and external heat roller assembly
        3. fuser nip measurement (ideally 10.3mm when you have a very accurate ruler, most techs use 10mm or 10.5mm)
        4. foreign objects that are stuck/ fused to these components
        5. condition of the stripping fingers
        6. it may also be the stock/paper used
        • artdigital
          THANKS
          Thanks for your help, the only problem was the cleaning web, i change the cleaning web for a new and thats it.
          • TechMate
            • Mar 2008
            • 285
            Hi. So your problem wasn't BIG at all!
