Your customer properly had wrong type fuser for machine. Check its part number, make sure it's correct. REmember the 7525,7535 is a same fuser and 7545,7556 is same one. Wrong voltage(120V or 220V) and wrong type of fuser will give you "fuser error"
Turn the power OFF and remove the Fuser Assembly. The Drawer Connector between the Fuser Assembly and the Main Unit ( P/DJ600) for broken/bent pins, foreign substances, burns, and etc.
Check whether the MCU PWB connector J431 is connected properly.
A different type of Fuser Assembly (rapid heating/accumulative heating) was installed.
NOTE:
When turning the power OFF, turn OFF the Power Switch first and then the Main Power Switch.
Measure the resistance between P600 pin-A11 and P600 pin-B9. Is the resistance infinite? Yes No Unanswered
Check the following connections for open circuits, short circuits, and poor contacts.
Hi Techs, I have the same error on a Xerox WorkCentre 7835i, the machine in the middle of printing and displayed the fuser system error accompanied by errors below 310.382.200, 377.901.00, 310.330.00, 310.370.00
Help me to resolve this.
Thankyou.
Herbert Nyirongo.
Thankyou.
Herbert Nyirongo.
after fix the fuser roll, see the attach and reset the fault in NVM 744-001 to 0
I replaced the fuser assembly with a new one and changed the NVM 744 001 to 0 the fuser error still appears
310.372.00 still appears on the fault history.
Help..
Herbert Nyirongo
Check again if 744-001 nvm is set to zero
Check the connector from machine in which the fuser connector enter - pj6000
Check connector pj 431 from MCU pwb.
Help..
Herbert Nyirongo
