xerox WC 7556 "fuser system error"
  • fosg2000
    • Mar 2016
    • 8
    Got an wcp 7545 that has fuser error
    can any body help me got this error:
    310-382
    please advice
    • vodo
      • Dec 2016
      • 36
      Re: xerox WC 7556 "fuser system error"
      Originally posted by George_H
      I need your help guys in this issue , PLEASE Help
      Your customer properly had wrong type fuser for machine. Check its part number, make sure it's correct. REmember the 7525,7535 is a same fuser and 7545,7556 is same one. Wrong voltage(120V or 220V) and wrong type of fuser will give you "fuser error"
      • seximibabay07
        • Mar 2013
        • 59
        Re: Got an wcp 7545 that has fuser error
        310-382
        please advice
        310-382 Fuser Thermostat Fault
        [IMG]pws://file/xerox/edoc/wc7556f/icons/arrwup.gif[/IMG]BSD On
        BSD 10.4 Fusing Heat Control (2 of 2)
        [IMG]pws://file/xerox/edoc/wc7556f/icons/arrwup.gif[/IMG]Description
        The Fuser Assembly Thermostat is broken.
        NOTE:
        When turning the power OFF, turn OFF the Power Switch first and then the Main Power Switch.
        [IMG]pws://file/xerox/edoc/wc7556f/icons/arrwup.gif[/IMG]Initial Action
        • Turn the power OFF and remove the Fuser Assembly. The Drawer Connector between the Fuser Assembly and the Main Unit ( P/DJ600) for broken/bent pins, foreign substances, burns, and etc.
        • Check whether the MCU PWB connector J431 is connected properly.
        [IMG]pws://file/xerox/edoc/wc7556f/icons/arrwup.gif[/IMG]Procedure
        Measure the resistance between P600 pin-A11 and P600 pin-B9.
        Is the resistance infinite? Yes No Unanswered
        • fosg2000
          • Mar 2016
          • 8
          #19
          NOTE:
          thanks, can you reply with printscreens from your PWS, cuz i can see the pictures from your post
          thanks again...
          • fosg2000
            • Mar 2016
            • 8
            #20
            can anyone share the service manual for WC 7545
            cuz need the details for :
            [COLOR=rgba(17, 19, 150, 0.901961)]310-382 Fuser Thermostat Fault
            thanks
            [/COLOR]
            • fosg2000
              • Mar 2016
              • 8
              #21
              found a blown fuse of 30mA, on the fuser, i replaced but keeps blowing , any help ?
              thanks
              • seximibabay07
                • Mar 2013
                • 59
                #22
                send all fault code plz!!!
                • fosg2000
                  • Mar 2016
                  • 8
                  #23
                  here....
                  check the pictures
                  • seximibabay07
                    • Mar 2013
                    • 59
                    #24
                    here....
                    check the pictures
                    [ATTACH=CONFIG]35488[/ATTACH]
                    [ATTACH=CONFIG]35487[/ATTACH]
                    [ATTACH=CONFIG]35486[/ATTACH]
                    [ATTACH=CONFIG]35489[/ATTACH]
                    [ATTACH=CONFIG]35490[/ATTACH]
                    hi check.....>
                    [IMG]pws://file/xerox/edoc/wc7556f/icons/wordproc.gif[/IMG] 310-381 Fuser Assy Illegal Fault
                    A different type of Fuser Assembly (rapid heating/accumulative heating) was installed.
                    NOTE:
                    [IMG]pws://file/xerox/edoc/wc7556f/icons/arrwup.gif[/IMG] Cause/Action
                    1. Turn the power OFF and ON.
                    2. Turn the power OFF and replace with the correct Fuser Assembly ( PL 7.1).
                      and Check...>
                      NOTE:
                      Check the following connections for open circuits, short circuits, and poor contacts.
                      If no problems are found, replace the MCU PWB.
                      Replace the Fuser Assembly ( PL 7.1).
                      good lucky
                    • hnyirongo
                      • Aug 2011
                      • 6
                      #25
                      xerox WC 7835i "fuser system error"
                      Hi Techs, I have the same error on a Xerox WorkCentre 7835i, the machine in the middle of printing and displayed the fuser system error accompanied by errors below 310.382.200, 377.901.00, 310.330.00, 310.370.00
                      Help me to resolve this.
                      Thankyou.
                      Herbert Nyirongo.
                      • seximibabay07
                        • Mar 2013
                        • 59
                        #26
                        Re: xerox WC 7835i "fuser system error"
                        Thankyou.
                        Herbert Nyirongo.
                        after fix the fuser roll, see the attach and reset the fault in NVM 744-001 to 0
                        • hnyirongo
                          • Aug 2011
                          • 6
                          #27
                          I replaced the fuser assembly with a new one and changed the NVM 744 001 to 0 the fuser error still appears
                          310.372.00 still appears on the fault history.
                          Help..
                          Herbert Nyirongo
                          • adriansto
                            • 2383
                            #28
                            Check again if 744-001 nvm is set to zero
                            Check the connector from machine in which the fuser connector enter - pj6000
                            Check connector pj 431 from MCU pwb.
                            • seximibabay07
                              • Mar 2013
                              • 59
                              #29
                              Help..
                              Herbert Nyirongo
