Need urgent help for Xerox Document Centre 480ST. Problems with Fuser Module
  • fandenivoldsk
    • Jun 2025
    I get the message "Pull out the Fuser Module, then firmly push it back in" message on the display on my Document Centre 480ST Xerox copier.
    I tried to do pull it out and back in several times, but without any luck. Anyone how know what is going on, and how to fix it?
  • Scarecrow
    • Oct 2010
    • 234
    Re: Need urgent help for Xerox Document Centre 480ST. Problems with Fuser Module
    Yep. But the safest approach if you are not a tech, is to replace the fuser first.
    • fandenivoldsk
      So it could be that it is just worn out and need a replacement?
      The strange thing is that it writes the same error message, even when I pull out the Fuser Module completely. It looks like the copier is not aware if it is connected or not.
