Re: Need urgent help for Xerox Document Centre 480ST. Problems with Fuser Module
So it could be that it is just worn out and need a replacement?
The strange thing is that it writes the same error message, even when I pull out the Fuser Module completely. It looks like the copier is not aware if it is connected or not.
Guest replied -
I get the message "Pull out the Fuser Module, then firmly push it back in" message on the display on my Document Centre 480ST Xerox copier.
I tried to do pull it out and back in several times, but without any luck. Anyone how know what is going on, and how to fix it?Leave a comment:
I tried to do pull it out and back in several times, but without any luck. Anyone how know what is going on, and how to fix it?Tags: None
