Xerox 6060 PWS in standalone mode
  • Kaz73
    • Mar 2015
    • 20
    Hi can one help please, tried to connect machine to laptop today but it will not connect I keep getting NO CONNECTION STANDALONE MODE ONLY can anyone help please?
    Kaz
  • tasosGR
    • Jun 2014
    • 23
    Re: Xerox 6060 PWS in standalone mode
    Kaz
    PWS 9.2 (with xp) or PWS 11.0 (win 7) ?
    Check serial cable that connect with your nachine.
    I suggest you try another cable.
    • Kaz73
      • Mar 2015
      • 20
      XP - Brand new cable USB / DB9 Serial cable, I have tried all the USB ports but still will not connect, I have installed the cable software that comes with the lead as well but still no joy. Am I supposed to do something else to tell the machine or laptop that new printer connected?
      • xcopytech
        • Aug 2006
        • 1794
        Did you set usb to com1 port.
        • tasosGR
          • Jun 2014
          • 23
          sorry, previous days, you had connected your pws with serial cable (using usb adapter ?).
          Because i know that many of usb adapter have problem to connect with machines.
          This is the reason that many of us use old laptop with serial port.
          • Kaz73
            • Mar 2015
            • 20
            No I did not, how do I set to USB to com1 port?
            • xtrain
              • Dec 2012
              • 233
              I use the old standby adapter, Belkin F5U409 for XP. This has proved to be the best usb to serial adapter for these machines. And yes, I always set the port to #1.
              • Kaz73
                • Mar 2015
                • 20
                Oh okay, thanks. what is the best cable to get for this?
                • xtrain
                  • Dec 2012
                  • 233
                  Go online to C2G (Cables to Go), order part # 02712, 10 foot male/female db9 serial cable, about $12.U.S. There is a C2G for the UK also.
                  • xcopytech
                    • Aug 2006
                    • 1794
                    In device manager open usb port on which you connect adapter and set it to com1
                    • Kaz73
                      • Mar 2015
                      • 20
                      Thanks, I have had a look on C2G and this is the item 3m DB9 RS232 M/F Extension Cable Product 81371, Is this the part you recommend?
                      Thanks again
                      • xtrain
                        • Dec 2012
                        • 233
                        Thanks again
                        Yes. I went to c2g UK and this is the proper cable.
                        • Hugh Hawley
                          Did you open GSN lock?
                          It could be the date on your laptop if it's an old one.
                          • xtrain
                            • Dec 2012
                            • 233
                            You need more than a serial cable. The newer laptops do not have a DB9 serial port, so you use an adapter that requires software loaded and the adapter plugs into the USB port , the serial cable plugs into the adapter. That is why we use the Belkin adapter as it always works with XP. Have tried many other adapters, but none work as good as the Belkin. Again, we set the adapter to port 1.
