pro 65 "copier not available" error
  • copierpro
    • Apr 2007
    • 270
    #16
    the only code
    in control panel through machine status button is "printer fault"
    • xcopytech
      • Aug 2006
      • 1794
      #17
      when press faults tab can check for fault code
      printing fault is message that machine can not print.
      have also option for last 40 faults
      • copierpro
        • Apr 2007
        • 270
        #18
        error code list
        faults just says "printing fault" and in "errors" log the last one was two minutes at power up 3.311.00
        • xcopytech
          • Aug 2006
          • 1794
          #19
          check attachment
          • copierpro
            • Apr 2007
            • 270
            #20
            just rebooted now it says 12.315.00
            which is different obviously
            • xcopytech
              • Aug 2006
              • 1794
              #21
              12-315 is stacker tray offset motor fault
              • copierpro
                • Apr 2007
                • 270
                #22
                P72 is unplugged!
                P72 runs thgrough behind wall and we found it is unplugged - how do I get access back there?
                • copierpro
                  • Apr 2007
                  • 270
                  #23
                  P72 = dv driver looks like
                  and we got to remove dv unit to get at it I believe
                  can you either send me rap on dv unit removal or just tell me? then I tihnk we got it licked
                  thanks a bunch
                  • copierpro
                    • Apr 2007
                    • 270
                    #24
                    P72 12-pin connector behind rear wall
                    I cannot see where this is supposed to plug in at all - any help/advice appreciated.
                    It is a white 12 pin connector with orange wires
                    • xcopytech
                      • Aug 2006
                      • 1794
                      #25
                      P72 have to go on ROS
                      • copierpro
                        • Apr 2007
                        • 270
                        #26
                        where is ros
                        I assume that is the center board viewed from back - I do not see a connetor male that will fit it?
                        • xcopytech
                          • Aug 2006
                          • 1794
                          #27
                          remove left side cover, maybe you will have to remove HCF if machine have it.
                          than you will se under developer assy, ROS.
                          On back side of ROS you should connect that P72
                          • copierpro
                            • Apr 2007
                            • 270
                            #28
                            we already removed the hcf and panel
                            and it is extremely tight back there - cannot even get hand under-back there
                            need to remove dv unit - it comes out 4 inches and locks - will not slide out - what am I doing wrong trying to slide the dv unit to get it out of the way?
                            • xcopytech
                              • Aug 2006
                              • 1794
                              #29
                              remove photoreceptor, remove toner bottle and then unplug one cable, big connector on developer assy
                              • copierpro
                                • Apr 2007
                                • 270
                                #30
                                got p72 in place
                                now we are faulting to 09.370.00 and 09.304.00
