pro 65 "copier not available" error
  • xcopytech
    • Aug 2006
    • 1794
    #31
    did you closed left cover and connect all connectors
    9-370 is transfer fault
    9-304 is BTAC fault (sensor on developer assembly)
    • copierpro
      • Apr 2007
      • 270
      #32
      we got 304 cleared
      we forgot to put dv waste tube back on dv unit so 304 is gone
      we are still getting 9-370 - we put left cover back on and double checked connectors in back we were messing with
      what is the trasfer area? the drum belt?
      • xcopytech
        • Aug 2006
        • 1794
        #33
        yes, transfer is in photoreceptor unit,
        if you have another photoreceptor try it
        do you have any other fault code like 9-372, 9-374 etc
        • copierpro
          • Apr 2007
          • 270
          #34
          no other codes are present
          just the 370
          we had a unit with 9k images made, removed, put in a new unit, then when I found out first one had only 9K images told them to put the old back in
          maybe the counter rest is messed up now with the old one back in there
          we will put the new one back in
          • xcopytech
            • Aug 2006
            • 1794
            #35
            try with new and check attachment
            • copierpro
              • Apr 2007
              • 270
              #36
              no voltage 34-38VDC on P66
              so should we swap out that board? I guess that is the ticket
              though this code never showed up until after we were fixing the P72 connection
              of course, could be that P72 just over rided this code
              • xcopytech
                • Aug 2006
                • 1794
                #37
                if you do not have voltages, check cables and if ok, try to replace SCAM PWB
                • copierpro
                  • Apr 2007
                  • 270
                  #38
                  scam is board
                  that P66 plugs into?
                  • xcopytech
                    • Aug 2006
                    • 1794
                    #39
                    p66 is on transfer detack hvps and p20 is on SCAM pwb
                    • copierpro
                      • Apr 2007
                      • 270
                      #40
                      swapped scam
                      same code issue
                      this code never appeared until we plugged P72 in - but I guess it could not appear with P72 unplugged.
                      this unit has 468K - I cleaned the donor roll on dv - looks real good.
                      this has got to be something simple
                      what next?
                      • copierpro
                        • Apr 2007
                        • 270
                        #41
                        9-582 17-16 correction to current fault
                        thgis is the fault code that appears on the WCP 65 web UI
                        what is this one
                        • xcopytech
                          • Aug 2006
                          • 1794
                          #42
                          Go to faults tab.
                          Only there you can find real fault code.
                          9-592 is status message which mean that printer is not available.
                          Machine have some of this codes 9-370,9-372,9-374 or 9-376.
                          Check which and follow that rap.
                          If you have 9-370 follow rap which i post earlier.
                          Try to change scam and transfer detack hvps pwb
                          • copierpro
                            • Apr 2007
                            • 270
                            #43
                            we just found out that
                            connector J104, which plugs into a string of connectors white boxes that ultimately lead to rear inside wall of process area, was completely gone. J104 is to left rear side of copier toward upper area
                            we are going to restring these white box connectors from rear, get J104 connected, reseat whote connector boxes inside wall, and I will bet we are good to go after that. these whote boxes are all interconnected to the process drum
                            • copierpro
                              • Apr 2007
                              • 270
                              #44
                              3-585 "machine has detected an IIOC PWB failure"
                              this is the message we now get through web UI - through the control panel we get only 9-370
                              the web ui is showing the true problem
                              which board is the IIOC?
                              • xcopytech
                                • Aug 2006
                                • 1794
                                #45
                                As I told you before.
                                WEB UI do not show fault code, just system message.
                                9-585 mean Unclearable process control fault declared.
                                Only fault tab and fault under tools menu can show real fault code.
                                Do you have service manual for this machine.
                                If not check with Manuals 4 You - Copier-Printer-Fax Manuals etc
