pro 65 "copier not available" error
+ More Options
Posts
  • copierpro
    • Apr 2007
    • 270
    power up then as soon a control panel user mode pops up error meesage "copier not available" come up with suggestion to power up/down or call service. Power up/down does nothing.
    I noticed fault 6-315 in web ui for machine; that points to scannner issue of some kind
    any quick tips? I put a new drum and fuser module in unit too.
  • xcopytech
    • Aug 2006
    • 1794
    6-315 is ROS (laser) related code
    mean that ros poligon motor can not reach or maintain simmer speed
    • copierpro
      • Apr 2007
      • 270
      thanks-so I should replace laser motor?
      I got a 460 parts machine here where is the laser motor? under the scanner I would assume probably a real pain in the neck to get to
      or can I teak the speed in service mode?
      • xcopytech
        • Aug 2006
        • 1794
        You have to replace ROS assembly (laser unit).
        ROS unit is under developer assembly.
        But you need laptop with xerox pws software to adjust laser data after replace ROS.
        • copierpro
          • Apr 2007
          • 270
          ros replace - actually it is 6-515 code
          6-515 17-17 The printer has detected one or more Raster Output Scanner (ROS) faults that cannot be cleared. A machine Power Off/Power On may help, Xerox service is required if the problem persists. Printing has stopped.
          I am at the shop now - I got to have this ready tomorrow
          • xcopytech
            • Aug 2006
            • 1794
            6-515 is not a fault code it is just system message.
            have to check in "faults" for real fault code
            (it will be some code for ROS)
            then work with real fault code
            • copierpro
              • Apr 2007
              • 270
              thanks
              I appreciate your time on this Sunday
              • copierpro
                • Apr 2007
                • 270
                I don't have the service book
                so I do not know the fault that leads to 6-515 sys fault
                do you know how to get into service mode? Maybe I can do a reset or something in there?
                • xcopytech
                  • Aug 2006
                  • 1794
                  check attachment!
                  on this machine you can not enter in diagnostic mode without laptop and xerox software.
                  • copierpro
                    • Apr 2007
                    • 270
                    6-515 is gone
                    I checked the dv unit put it back cleaned rollers and hooked everything back up
                    the error codes have gone away in web ui display
                    now, I go all the way to normal display at power up and in faults under machine status it says "printer falult, call for service"
                    and, of course, "copier not available" on the display.
                    • copierpro
                      • Apr 2007
                      • 270
                      I am running xeroxgraphic sys routine now
                      maybe that will clear up the printer fault
                      will check status codes in tools/faults to see if any can lead to rap procedure
                      • xcopytech
                        • Aug 2006
                        • 1794
                        on right side of touch panel have three gray buttons,
                        press the lower one and go to faults tab.
                        there you should see real fault code
                        • copierpro
                          • Apr 2007
                          • 270
                          will check fault codes
                          question - paper feed rollers are marked end of life in consumables, but I looked at them, cleaned them w/alcohol, they look perfect not worn - how can I reset feed rollers counter? Do I need the software/laptop?
                          • copierpro
                            • Apr 2007
                            • 270
                            xcopy - only fault now is printer fault
                            through control panbel machine status function
                            I am trying to run xeroxgraphic routine but it seems to just keep testing - does not complete the test
                            I notice 4 or 5 loud raps at rear on powerup from the fuser section but it is seated properly
                            I know I got something simple here but I am not making much progress it seems
                            • xcopytech
                              • Aug 2006
                              • 1794
                              paper feed roller can reset through tools.
                              but machine can work even they are 0 days left.
                              which fault code you have?
                              check that on fault tab.
                              withou fault code i can not help you much.
