xerox work center 5765
  • tbkarthic
    • Feb 2011
    • 66
    [Misc] xerox work center 5765
    i have error masage when gived print or copie
    xerographic fault
    open fron door check paper for 4b
    but thare not jamed paper
    after restarting that machine will getting ready. but when i give copies or print showing this massage. how can i solve this problem.
    drugstore-catalog.com
  • Corder
    • Nov 2014
    • 105
    Re: xerox work center 5765
    xerographic fault
    Is there any error number showing with the message?
    • tbkarthic
      • Feb 2011
      • 66
      no sir i have this massage, on attached image
      • Exok
        • Jun 2011
        • 750
        Have you tried installing a new drum cartridge?
        If you select "ignore" then go to the machine status screen and look up active faults it should give you an error code #. Report that back for better results.
        • tbkarthic
          • Feb 2011
          • 66
          is this ok?
          • Corder
            • Nov 2014
            • 105
            is this ok?
            I believe that your HVPS is dead, you should replace it before trying new drum unit.
            • tbkarthic
              • Feb 2011
              • 66
              i have checked with another working machine but same
              can you have firmware for this model?
              • Corder
                • Nov 2014
                • 105
                You can have it too, it's available on Xerox support site.
                So what exactly you did to check? Installed working LVPS on the machine and it didn't helped?
                • tbkarthic
                  • Feb 2011
                  • 66
                  i have altboot only i need a full firmware for this machine, and i installed,checked working hvps it's fine sorry for my bad English
                  • Corder
                    • Nov 2014
                    • 105
                    Once again - you can obtain firmware from Xerox support site. Use search on model number and you'll find it in the Download section.
                    • Richard.Xerox
                      • Jun 2015
                      • 73
                      I suspect LVPS 24V rail is dead.
                      If you have a spare LVPS try replacing that.
                      • tbkarthic
                        • Feb 2011
                        • 66
                        dear friend i'm new for xerox, i trained only konicaminolta and kyocera service but no mor idea on xerox models plz locate that lvps on machine i have spare machine on my office
                        • Corder
                          • Nov 2014
                          • 105
                          I just wonder how you checked HVPS if you can't locate LVPS )
                          • tbkarthic
                            • Feb 2011
                            • 66
                            [ATTACH=CONFIG]29817[/ATTACH]
                            • Corder
                              • Nov 2014
                              • 105
                              this is hvps right?
                              Yes, it is.
