xerox work center 5765
  • tbkarthic
    • Feb 2011
    • 66
    #16
    Re: xerox work center 5765
    Originally posted by Corder
    Yes, it is.
    i have lvps and drum unit but still same anybody have some other idea? thanks for your replays friends
    drugstore-catalog.com
    • xcopytech
      • Aug 2006
      • 1794
      #17
      First follow 09-060 RAP procedure from service manual.
      Go to commponent control and check hvps output to see which part of hvps make error.
      Did you check developer assy?
      • CopierTechofOmens
        Agitating Artificer
        • 268
        #18
        Also try cleaning the Transfer and main charge coros first
        sigpic
        • tbkarthic
          • Feb 2011
          • 66
          #19
          i already did that but same
          • Samuel Ortega
            • 8
            #20
            By the imagenes of the messages showed by the workcentre, for the code xerographic fault, need to replace the cartridge of the drum and give him service of maintenance to the workcentre, the HVPS this well
            • tbkarthic
              • Feb 2011
              • 66
              #21
              sorry i can't understand i have already replaced durm unit and hvps and lvps and dc controller pcb no more changes on that machine. this machine firmware is tooo costly i dont have interest in spend money for that
              how to clear maintenance count?
              • Corder
                • Nov 2014
                • 105
                #22
                There's no any maintenance counter as far as I know.
                • xcopytech
                  • Aug 2006
                  • 1794
                  #23
                  Check wiring from hvps to developer assy.
                  • bluebear
                    • Jul 2014
                    • 16
                    #24
                    Hi, forum please correct me if am wrong in saying if the gentleman instigate the alboot software to his machine, the machine is more or less reset to factory default and for that matter a new firmware might not be required for fault / diagnostics purposes?
                    Unless his intension is to upgrade the current firmware and not necessarily for the troubleshooting reasons.
                    I ask this question so that he can narrow down the scoop of possiblefaults, this could be a fualty sensor or sensor corvered in waste toner.
                    • Corder
                      • Nov 2014
                      • 105
                      #25
                      More likely it's the wiring.
                      • adriansto
                        • 2388
                        #26
                        Remove transfer /detack unit from machine and try again to make copies.
                        Watch if the paper start to feed and where it stop.
                        • tbkarthic
                          • Feb 2011
                          • 66
                          #27
                          i checked paper stop position for first tray stop on drum unit and form 2nd tray and 3 or 4th tray stop on left door front edge on developing unit bottom, i have checked paper path sensors its are working
                          • xcopytech
                            • Aug 2006
                            • 1794
                            #28
                            Did you test hvps output from diagnostic (dc330)?
                            Did you check wiring from hvps to developer assembly?
                            • Richard.Xerox
                              • Jun 2015
                              • 73
                              #29
                              Just had a call for this same fault the other day, resolved by replacing the transfer/detack unit (which should be replaced when changing the drum)
                              Might not be that but it's the first place to start.
                              • nilak
                                • Aug 2010
                                • 72
                                #30
                                Check first if CR16 is light on on IOT board (Top, Left). If it is check on F1 or PJ27 pins1,2 for true 24v. If CR16 is off or 24v are below 23.2v unplug HVPS from IOT and power again! if it doesn't get them back go for 24v Rap.
                                If not - plug the HVPS back and try to unplug Detack, Transfer and Developer Bias one by one (with POPO) and check if 09-060 will disappear!
                                Still not get the short? - try the HVPS wires (unplugged) one by one to the ground for shorting (47k is still short)!
                                There is no so much left - IOT, IOT corruption, arcing and so on...
