RP 3700 Drum / pressure roller jam
  • lberlen
    • May 2025
    Hi Folks,
    I can not seem to get the drum back into the rp3700 - I noticed that the bottom of the drum is hitting the pressure roller preventing it from going in.
    Does anyone know how I can make the pressure roller go down?
    thank
  • Baphomet
    Copier Technician
    • Aug 2008
    • 293
    You can lower the pressure roller with the pressure roller lever behind the back cover of the machine.
    • joelsa12
      • Nov 2008
      • 260
      Pressure Roller Stuck in up Pos.
      If you were take out the screws and the connectors holding the PSB and swing it open, You will see two large springs. The arm that they are connected to needs to be pulled to the right until the machine locks the pressure roller into the down position. There is a free rotation button on the main MCTL board that will do this for you. By pressing this button the machine will rotate around and will lock the roller in for you. Unless the pressure lever is bad.
