RISO RP3700 blank lines through image via USB only
  • ThiccPoetry
    • Apr 2021
    • 2
    [CQ] RISO RP3700 blank lines through image via USB only
    Hi Guys,
    I am having an issue with my RISO RP3700.
    When creating masters via the inbuilt scanner the prints produced are clean however when I print from my laptop via USB I get small blank (white) lines through the print. Some have suggested in other forum posts this may be a printer head issue however due to the clean scanner bed masters/prints I think its more likely a software/driver issue.
    Any help or troubleshooting advice would be greatly apprecited.
    Cheers
    - C
  • GIUBOSS
    • 1396
    Re: RISO RP3700 blank lines through image via USB only
    Originally posted by ThiccPoetry
    Hi Guys,
    Cheers
    - C
    hi, I think they are two ways of printing with clearly different settings. Have you tried with print adjustments in the driver as you mentioned? A bit old duplicator. What are the conditions of the drum, ink?
      Hi Guys,
      Cheers
      - C
      what OS on your laptop?
      if win10 delete the last update and use PCL6 driver.
      upload PDF's of the problem. check the faq for attaching images: https://www.copytechnet.com/forums/f...b3_attachments
