Hello;
I have a drum locked inside the unit previously and I follow some posts here to unlock the drum from the unit. Since the drum roller inside is not in the "home" location, so I open the back cover of the unit and pull the belt until it comes back to "home" position. Now I can insert back the drum.
However, when I pull the belt, I also unlock a hock at the back of the unit that control the "inking roller" -- I don't know the terms but "inking roller" means the plastic roller that sit right below the drum that press the paper to the drum in order to let the drum press the content on the paper.
So, now the "inking roller" will not come up and press the paper to the drum. Paper will not pass through the unit anymore and now I am stuck.
Any idea to get this problem fix? Thank you very much!!
Chris
Chris
