RZ-220UI
    • 23008
    RZ-220UI
    We've got a few of these cluttering up the warehouse, and I was hoping that one of you Riso guys could point me in the right direction. I've been a copier guy for two decades, but have never touched a duplicator.
    I'll start right off by saying they've been sitting in the warehouse idle for at least a year. I know that liquid ink systems don't like to sit idle. The more ink flowing the better.
    The first one should be fairly straightforward. "Replace Master Roll" is displayed. I think I may even have a master roll.
    The second and fourth both display "20" when I try to make a master. The second one will actually print from some old master still stuck on. It looks like a third grade history test. The fourth won't do that.
    The third one shows a red LED at the #3 on the illustration of the machine. It might be a jam, maybe something else.
    I haven't found an operator's manual yet, but haven't quit looking. I'm not interested in doing anything in-depth with these machines, I'd just like to pass some paper, if they're able. Anybody interested in purchasing, please send a private message. =^..^=
    • 23008
    bump
    no Riso people? or too hard to fix? =^..^=
    • cboyer
      Field Service Support
      • Dec 2010
      • 6
      your machines showing 20 have been defaulted to need 20 or more copies input before it will make a new master etc. the one with the 3 lit up means it needs the ink replaced or installed. Hope this helps
        • 23008
        Thanks! I'll fiddle with these more next week.
        • joelsa12
          • Nov 2008
          • 260
          if there are any issues to this machine hold down the * key. the machine will then give you a code which can be looked up in a user manual or on the internet and will point you to what the machine needs. if you have any other questions let me know. i have been working with these for awile(14 years)
          • pbbsinc
            • Nov 2005
            • 92
            If you need a tech & parts manual, email me with how to get them to you. They're 61,180kb & 6215kb pdf's. jay@pbbsinc.com
              • 23008
              Thanks everyone. I've got the users manual. Just lots of calls right now. I'll check back. =^..^=
              • riso specialist
                • Aug 2009
                • 40
                more info working on riso for 30 years can help u fix anything
                • Neos Eye
                  • Dec 2010
                  • 20
                  Re: RZ-220UI
                  i need a service manual for this model (riso 220 ui)..please send me a copy...wires on my machines are broken/eaten by rats..and the wires are not color coded..thanks in advance..my email add nomerevasco@yahoo.com.ph
                  • berryna
                    Re: RZ-220UI
