Hi I have a GR 3770...and loaded it up with this drum that I forgot had given me problems in the past. Now suddenly I have an alignment issue with making masters. I'm pretty sure that this is not a general alignment issue, because when i put in drums with masters that were burned previously to having the issue they print perfectly. The main problem is that the print is 25mm to the left (so with a big white space on the right margin). Also when i look at the drums it seems like the image on the master starts way closer to the top than it did on masters that were burned previously.
I tried going into test mode and using 87 (scanning start position adjustment (FB) but this made no difference.
Would very much appreciate any insight/suggestions!
Thanks!
Thanks!
