Riso EZ370 error code
  • bcp
    • Mar 2008
    • 57
    [Error Code] Riso EZ370 error code
    Anyone know what P-04-513 error code is & how to fix? thanks
  • laitang
    • Nov 2012
    • 627
    Re: Riso EZ370 error code
    The overflow sensor is ON for a set number of times in succession during the 10-millisecond interval overflow-sensor check.
    Press Reset Key after correcting the ink overflow condition. (No ink on the ink overflow sensor.)
    • jermyth
      Riso dude
      • Mar 2011
      • 441
      If the reset doesn't work there can be two causes for the code. Primary cause is the one-way squeegee gear is slipping, needs replaced by a RISO tech. Second cause is dry ink on ink bead stuck on the overflow sensor. I've seen this happen several times with color drums, especially red & bright red. Something about RISO's red pigments has given me more problems then its worth.
      Good luck.
      • bcp
        • Mar 2008
        • 57
        thanks for quick reply. I guess that the sensor just needs cleaning. Is there any info on how to get into the drum? thanks
        • jermyth
          Riso dude
          • Mar 2011
          • 441
          Get a manual. See Paul with Justmanuals.com he advertises on here.
          There is a "window" that can be opened inside the ink tube holder that can give one limited access to the ink sensors.
          Good luck.
          • Azarov
            • Feb 2013
            • 1
            Usually, the occurrence of this error is due to the poor quality or ink or wear clutch shaft inside the drum.
