brother hl 1430 all light flashing
  • Orion2010
    • Jun 2015
    • 176
    brother hl 1430 all light flashing, any ide? thanks
  • travi
    • Jan 2008
    • 129
    Re: brother hl 1430 all light flashing
    Disconnect print data connection from printer. Turn off printer. Turn on printer. if it comes to a ready state print an internal test page. If test page prints you most likly have a corrupt print job in print que. If doesn't come to ready or print internal test page, you need a main board
    • Orion2010
      • Jun 2015
      • 176
      Travi,
      printer not make waring up only light flashing
      thanks
      • travi
        • Jan 2008
        • 129
        Then you need a main board
        • copydocinc
          • Mar 2015
          • 263
          There is a reset you can try. It might work, It might not.
          Hold down the button until all led's are on solid and then while still holding down the button, turn off the printers main power switch.
          Release the button and turn it back on.
          You might have to do this with the front door open, but try it both ways.
          It's worth a shot.
            • 22997
            Many Brother printers and MFPs that do not have a display panel, display error messages via sequences of blinking LEDs. The sequence of long or short, and which lights, indicates what sort of fault you have. Please examine your service manual. Sometimes if you can access the web interface it will display the error condition. =^..^=
