Paper Curling
  • bullet34
    • Apr 2017
    • 11
    Paper Curling
    I have a couple of MFCL8600cdw machines that are only at about 500 prints. The customer was complaining about a severe curl to the prints. I flipped and inverted the existing paper......no improvement. I checked the paper quality and pulled from a fresh pack of paper to rule bad paper "moisture" out. I then messed with the paper thickness settings as Brother recommends doing. Last, I selected the "Reduce Paper Curling" in the driver. That was almost laughable, as it made no improvements at all. Any other things I can try. From what I saw, those were the only things Brother recommends to remove paper curling problems.
    Thanks ahead for your help.
  • solorajder
    • Jul 2010
    • 106
    Re: Paper Curling
    Replace the fuser unit
    Sent from my GT-I9195I using Tapatalk
    • bullet34
      • Apr 2017
      • 11
      Re: Paper Curling
      Replace 2 fusers that were just unboxed from factory less than a month ago? I would think this would be a big problem if the fusers are a problem out of the box.
      • driving lots of miles
        • Jun 2016
        • 393
        Re: Paper Curling
        I still think it would be a paper issue especially since this is a new machine. If not paper and since you have tried the Brother remedies it has to be the fuser is running to hot and that would be a warranty issue with Brother as this is a new machine.
          • 22922
          Re: Paper Curling
          Along these lines, I was going to suggest decreasing the fixing temperature 5C to 10C (if there's a way to do that). =^..^=
          • Elmtech
            • Nov 2013
            • 155
            Re: Paper Curling
            Have you tried updating the firaw are? Also have you tried a different brand of paper. Lastly check there is decent airflow for the machine to vent heat especially the rhs of the machine.
            • Elmo
              • Feb 2010
              • 541
              Re: Paper Curling
              Try a good quality brand of 80gsm laser paper HP or Xerox
              The Economy brands of paper do tend to curl more
              I Used To Live To Fix Things Now i Fix Things To Live
              • bullet34
                • Apr 2017
                • 11
                Re: Paper Curling
                I have already ran the firmware update tool Brother provides. Everything was current. I'm trying to track down the path to change the fuser temp if there is in fact a way to do that. On the next trip over I am taking a high quality 24lb laser paper to see if it reacts any different. Luckily the account is only a few blocks away from the shop. Thanks for all the suggestions. I will let you know.
                • bullet34
                  • Apr 2017
                  • 11
                  Re: Paper Curling
                  Update: I used a high end 24lb paper and the curling improved (was 2" or more), but not gone completely. However brother says that a 1" curl is within specs on this model. The temps and humidity levels were in range of specs. So since I am now within specs, I would consider it the best it is going to get. I even ran it out the back door, and it still had a bit of a curl to it. There is no way to adjust the fuser temp on this model per Brother Tech Support and manuals.
                  Thanks for all the recommendations.
                  • allan
                    RTFM!!
                    • 5459
                    Re: Paper Curling
                    Can always mess with the pressure springs.
                    Whatever
