Brother fuser film grease
  • gideon
    • 283
    Anyone found a lasting grease for the fuser film on Brother printers that are using the DR-720?
    Everything I tried failed after short time.
    Re: Brother fuser film grease
    the fuser come already greased up... you cannot get genuine fuser films... so where are you getting them ?
    and you do know that those fusers are only good for 100k... the heating resistors start failing after that
    • gideon
      • 283
      The problem with those fusers is that after 30k their original grease dried and all what I need to do is take the film out, clean the old grease and regrease, put back the film and it works fine (I did it many time), but only for short time then the high temp grease that I tried failed after a short time (I tried 4 types), even the uniflor grease that I'm using for years on hp films failed.
      The new replacement fuser from Brother should take care of the problem (that what they said - we will see), but why to pay $150 when all what it needs is a new grease.
        • 23009
        Have you tried Molycote HP-500? It's expensive, and the best high temp grease that I've used.
          ok..sorry am a certified tech..and most times my customer understand the warranty on the fuser is out ( and are willing to pay..)
          but I am willing to try and save non contract customers ( only service manager .. don't get to decide if customer has to pay ** DESPITE guidelines set up 5 years ago... and don't get me started on the "Barter" customers)
          did you keep records on how many pages each grease passed before failure? which one worked best?
          • gideon
            • 283
            The longest it works was 3-4 weeks with a blue grease I got from a motorcycle mechanic, I need to check the name, but it didn't last long enough.
            Symptoms for dry grease start with lighter and fuzzy print, it will detorriate to smears and jams.
            • fixitfast
              • Nov 2009
              • 21
              I have Grease for these fusers. Printer Spare Parts by Fix It Fast Brisbane Australia
              Application is different to hp/canon as the heater is metal and not ceramic. The heating element is a traditional halogen lamp covered by a metal plate. All done to avoid Canons precious patent. The units are plagued with film stalling problems as the original grease isn't applied properly (or enough) at the factory. You need to grease the heater plate and the inside of the film 1.5 inches in each end after cleaning everything with turpentine.
                You are wasting your time using anything but proper fuser grease like what blackcat recommended.
                • AL parts
                  • Jun 2019
                  • 61
                  We provide our customers with the same silicone grease as HP. This machine uses a metal film, right? Now many of our customers have replaced the fixing film with DR3400, which is resin type.
                  www.gzanling.com
                  • Gift
                    • Mar 2011
                    • 2459
                    Sometimes it's not just the grease but also the pressure plate causing too much friction even with lubrication.
                    • tsbservice
                      Field tech
                      • 8020
                      This will happen way more often when compatible toner is used. It will contaminate whole printer includes fuser.
                      • fixitfast
                        • Nov 2009
                        • 21
                        Spot on the money there with the non genuine toner, But you can use it too your advantage if the customer buys the non genuine toner exclusively from yourself. Increase the cost of the non genuine toner and offer to the customer to service the printer for free when required (re grease the fuser). Customer thinks your offering outstanding service and value for money which usually results in them telling all their business friends (free advertising) result is you put more money in the bank. The key to making non genuine work is to clean out any genuine toner residue out of the printer and drum unit before switching to non genuine. Molykote HP500 grease wont work for very long as Brother is metal heater plate on metal fuser film, not ceramic heater on metal film as in hp fusers. The New Brother HL-L5200dw have a redesigned fuser which is proving to be far less problematic.
                        • tsbservice
                          Field tech
                          • 8020
                          Yes they changed fusers part number several times. I have had some brand new fuser units to exhaust smell of burnt cables frightening customers that printer will be set on fire every moment...i guess they put too much grease at factory. Not fun replacing them especially on new printers but I guess it's what it's.
                          • deputydogg
                            • Nov 2015
                            • 172
                            I have a customer that has a DCP-8155 with 575K on it, I use UniFlor 8172 Fixing film grease which usually last 6-8 months. I think I have changed the fuser unit 3 times. They love the machine and want to keep it going. From the few "newer" Brother machines I've seen I don't think they will last as long as this one has.
                            • tsbservice
                              Field tech
                              • 8020
                              Original or compatible toner? I have MFC L6900 machines when they do low coverage fusers last 250k+ prints, only original toners used. You've put in any other crap and fusers die way too prematurely.
