Brother MFC-L9550cdw How to reset Fuser & Laser Unit counters
  • copydocinc
    • Mar 2015
    • 263
    I've reset toner counters on this model and drum, transfer counters on other Brother models,
    but I cant figure out how to reset the Fuser or Laser unit counters on this model and the reset process
    for other models doesn't work on this model MFC-L9550cdw
    Help please
    Re: Brother MFC-L9550cdw How to reset Fuser & Laser Unit counters
    Help please
    do you have the manual? PM me
    • copydocinc
      • Mar 2015
      • 263
      I'm thinking, if I had the manual, I would also have the answer?
      Or I would find out that it is not possible to do this reset without replacing the fuser or laser units
      I do not have the service manual.
      Is it possible to do this reset with pushing the right buttons and if so, what are the right buttons and sequence?
      Help please
      • tsbservice
        Field tech
        • 8081
        It's All in Service manual, if you need one post a request in proper section I'm sure someone will help with.
        What's the point if endusers have sims to reset parts without replace them
        • Dickie
          • Nov 2011
          • 190
          Assuming you are a tech
          Maintenance mode try either 84 or 88 for parts life reset.
          Usually comes up PF kit first, use arrow to scroll to fuser and laser then o.k then yes or start
          • copydocinc
            • Mar 2015
            • 263
            You assume correctly. 36 years.
            How do I get into 84 or 88?
            • Dickie
              • Nov 2011
              • 190
              Put the machine into maintenance mode as you would with any Brother product then use maintenance 84 or 88.
              If you do not know how to access maintenance mode let me know
              • copydocinc
                • Mar 2015
                • 263
                I'm not sure, but is that the hold down the 6 and 2 thing?
                • Dickie
                  • Nov 2011
                  • 190
                  I have sent you a private Message with the keystrokes although I'm fairly sure it's easy to find on google.
                  If you are still struggling PM back or repost here
