Help me to solve troubleshoot problem to fix Brother Printer Error 50?
  • katew8161
    • Oct 2019
    • 3
    [Error Code] Help me to solve troubleshoot problem to fix Brother Printer Error 50?
    Please help me to solve my troubleshoot problem to fix
    Brother Printer Error 50.I am trying to solve problem in many ways but still getting same problem occurring.So,Please Help me to Solve by giving your suggestions.
  • tsbservice
    Field tech
    • 8028
    Re: Help me to solve troubleshoot problem to fix Brother Printer Error 50?
    I don't want to sound rude...but. Go and find a tech. From your post it seems you are not capable of even giving us proper description.
    Good luck.
      It may be just me...
      but knowing:
      the model #
      what happened before it kicked this error?
        • 30341
          • 37547
          My protection software is blocking the link you posted as a fraudulent site.
            Slim, my link? What viri/mal/track software?
              • 37547
              The original poster's link. I use Malware Bytes Anti malware.
                Slim,
                Me too 'Panky![emoji4]
                • copyman
                  Owner / Technician
                  • Sep 2005
                  • 4731
                  Hi,
                  Don't listen to these other techs. They are a bunch of trouble makers.
                  I will help you with your machine and make you feel good doing it.
                  1st, take machine to nearest dumpster
                  2nd, as you are throwing machine into dumpster yell as loud as you can "I HATE BROTHER" !!!
                  There you go as promised all fixed. I gurantee you will feel so much better after this.
                  Seriously, since you didn't mention the model # not sure if you had an all in one, stand alone fax or printer? Think that 50 code is same as HP and something with the fuser. Not worth repairing if it is fuser. Fuser probably cost more then machine.
                  Here is some more free advice:
                  Replace an all in one with a Kon/Min or Canon
                  Printer only, Kyocera or Ricoh
                  Fax only, Canon
                  Don't get tricked into the Brother game of separate drums & toners. You want a unit that toner & drum are together in one cartridge.
                  * By the way fellow techs just kidding about troublemakers.
                  By the way does brother count with providing tech support. Thought this site was only for "real" office equipment
                    Originally posted by copyman
                    Hi,
                    There you go as promised all fixed. I guarantee you will feel so much better after this.
                    **** AMEN TO THAT!****
                    Fax only, Canon
                    **** no offense taken on my part... I knew where you were going with it ****
                    When I was with my last employer, I hated that service call for either Samsux or Brother! The Bro Ink printers were FUCKING JUNK! and Samsux laser units are just as bad!
                    • dalewb74
                      • Feb 2018
                      • 1160
                      Hi,
                      Fax only, Canon
                      why would you want a toner/drum unit that doesn't separate? so that if the toner runs out then you have to replace the drum that doesn't need replacing? or vice versa?
                        • 37547
                        HP has been doing that for years.
