Brother DCP-L2552dn: scanner error
  • spree
    • Jun 2012
    • 211
    Hello, the scanner punches to the left side of the machine - than scanner error comes. Whan I turn on the machine, the CIS unit (scanner) lights up for few seconds.
    What could be wrong? I think only these three components:
    - D00G04001 - FIRST SIDE CIS UNIT
    - D00G05001? - FIRST SIDE CIS FLAT CABLE
    - D00MZD002? - MAIN PCB ASSY (main board)
    But how to know which one, when you do not have other spare parts?
    Flat cable can be measured - O.K.
    Do you have any idea, how to exactly specify the defective spare part?
  • tsbservice
    Field tech
    • 8062
    I would go for the CIS unit.
    • dalewb74
      • Feb 2018
      • 1167
      what is the actual code that you get?
      • spree
        • Jun 2012
        • 211
        On the display: scan unable AF (without error code).
        • dalewb74
          • Feb 2018
          • 1167
          from what i see in a google search it has to do with the fax.
          • spree
            • Jun 2012
            • 211
            It was: - D00G04001 - FIRST SIDE CIS UNIT. Now it is working fine.
            • tsbservice
              Field tech
              • 8062
              Thanks for leaving feedback.
