MFC-L861, skewing images...
  • Oystercopy
    • Oct 2009
    • 623
    Hey guys,
    So I've gone out to this machine, and it is skewing (tilting) the image to the right of the page, both on paper tray and Bypass.
    I've gone in and cleaned the registration roller (which seemed to have a lot of buildup, for some reason) and still it skews. I believe this to be happening prior to image formation and fuser, so that's why I went for
    the reg roller.
    Any help appreciated!
    OC
    • 23008
    Re: MFC-L861, skewing images...
    Could this be a Brother MFC L8610CDW, maybe?
    I don't seem to be finding references to the model you indicate. =^..^=
      • 23008
      If it is the Brother MFC L8610CDW, did you check to see that the imaging drawer is latched in on both sides? =^..^=
      • Oystercopy
        • Oct 2009
        • 623
        it IS the 8610 Black Cat, thanks for that!
        I didn't see a latch on the right side, only the left (green handle?)
        OC
          • 23008
          No, only one green lock lever, down locked, up unlocked.
          Also check that both the envelope pressure levers are set to the upper position (plain paper). =^..^=
          • Oystercopy
            • Oct 2009
            • 623
            Oh, OK! Where are those, on the fuser or something? Or in the paper feed area?
            OC
              • 23008
              Two gray levers, opposite sides of the fuser. =^..^=
              • Oystercopy
                • Oct 2009
                • 623
                Thanks BC, I'll have the customer try that. Although I wonder how this could cause the development of the image to be skewed before the fuser?
                I would also think I would have wrinkling too, or am I thinking about that the wrong way?
                OC
                  • 23008
                  I gathered what I did from the Brother online users manual. You could too. =^..^=
                  • tsbservice
                    Field tech
                    • 8014
                    Hey OC do you need SM?
                    If image is tilted that means it happens before fuser so grey envelope levers(normally should be in upper position) are not the cause of this.
                    I would check for hiden bit of paper in reg section, reмove drum unit a belt unit and check for foreign particles and if they seat evenly level.
                    • Oystercopy
                      • Oct 2009
                      • 623
                      Thanks TSB... yeah, I wondered how the fuser levers would cause this if it's happening before (or during) image formation.
                      I just talked to the customer this morning, and she's been re-using label sheets, over and over again. I suspect she might have gotten a label stuck in the registration section along the way (somewhere, I can't see it), but
                      customer does not want to spend a lot on repairs, so I told them the next best option is to replace it with another disposable machine.
                      OC
