Brother HL-2270 drum light
  • ldfrepairs
    • Oct 2012
    • 148
    [Error Code] Brother HL-2270 drum light
    Can anyone advised if there is a way to bypass the drum error for the brother hl2270? I performed the drum reset procedure but does not work.
    drugstore-onlinecatalog.com
  • tsbservice
    Field tech
    • 8010
    Re: Brother HL-2270 drum light
    Maybe change drum, reset on dead drum unit doesn't do any good.
    • ldfrepairs
      • Oct 2012
      • 148
      I did replace drum unit and perform the reset procedure but does not work.
      • dalewb74
        • Feb 2018
        • 1153
        might be a defective replacement drum. i would try another one? i sure hope it's a drum from brother. best well to tell, is the word brother stamped into the plastic?
