Brother MFC - L5700DN
  • Khumz
    • Feb 2020
    • 63
    Brother MFC-L5700dn, i replaced a faulty power supply board on this machine. I switched it on and it did power on, initialized all was fine. It poped up message calling for drum installation which was not inside the machine at that particular time. I switched it off and normal shutdown went through well. I installed drum unit and upon switching it back on nothing happened, no display, no moving motor or running fan except Home key light pop up. I removed power and removed drum unit , switch it on again still nothing happens. Any suggestions please.
  • Gift
    • Mar 2011
    • 2459
    Re: Brother MFC - L5700DN
    What's the voltage of the goldcap?
    Try unhook the power cable and hold the power button for 10secs then insert the power cable again and try turning it on.
    • dalewb74
      • Feb 2018
      • 1167
      have you tried a different outlet? is it on any kind of surge protector? have you tried a new power cord?
