Brother DCP 8060 replace PF Kit came up, did that then turned power off and unplugged to reset, but replace PF Kit still appears.
replace PF Kit wont go away
Press 88, display reads "Parts Replacement"
^/v to "Reset PF Kit T1"
OK or Start
Stop to exit. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^= -
Are you having trouble finding it in your service manual? Its on pg 295.
It looks like this:
maintenance mode&#46.JPGIf you'd like a serious answer to your request:
