Brother DCP 8020
  • cucuklotz
    • Mar 2007
    • 611
    Brother DCP 8020
    I went to cust office to clean optics,I took Adf off and scanner,not a big deal even though this is first one Ive worked on. When I put back together as machine is turned on ,adf motor turns and I get "remove original message and then press stop" Every time I press stop key,adf feed rollers spin and the same message comes back.I was very careful taking apart and putting together. I thought I may have switched connector from scan moter with other 4 pin connector but Ididnt.Then I thought i may have put a connector backwards but its impossible with pin location to do so.The machine was working before this . I was very careful in working on machine so this surprised me. Any help would be REALLY appreciated
    Thank you, ANDY
  • raym
    • Apr 2005
    • 62
    sounds like a stuck sensor or maybe a dislodged sensor.
    hth,
    ray
    • djbass
      • May 2008
      • 167
      Pretty much what Ray said. The original sensor (one in the top that detects when you insert a piece of paper inyo the adf) sounds like it is stuck or dislodged.
      No, I will not send you Manuals, Software or your own little repair Genie to fix all your problems for you.
      • wtroll
        • May 2008
        • 85
        Have you turned off the machine before unplugging the connectors?
        If no, the original sensor may be failure.
        Otherwise I think It's a connector problem, check all connectors you have unplugged and their pins.
        Good luck!
        • cucuklotz
          • Mar 2007
          • 611
          Brother dcp 8020
          Hi,
          Thanks for help,customer ended up buying another machine,which I paid 1/2 for(out of guilt)
          Andy
