Brother Itlfax 2600
  • ABCOPIERS
    • Aug 2025
    Brother Itlfax 2600
    Can anyone tell me the part No. for the fuser unit? I have an unresettable error code 76. Thanks, JamesR.
  • Ricky965
    • Mar 2008
    • 36
    Brother Fax
    Many of those Brothers have fuser problems when error 76 or 77 appears. Often the thermistor is bad or other parts. If you reset the error, be warned that temperatures will rise fast in the fuser and rubber will fuse to rubber.
    I'm not sure about that model, but most of them you press:
    Menu/Set *2864 to get into maintenance mode, then 91, then 99 and exit. 91 is parameter reset & 99 is exit
    Some are Menu Button *91 then 99 to exit
    Some are function * 2864 quickly, then 0 and 1 for a reset. 99 exits the maint mode
    • choicecopyguy
      • Mar 2006
      • 111
      UU135001 120v for USA and Canada
