2920 jamming
  • sharphead
    • Aug 2009
    • 285
    2920 jamming
    We have sold quite a few that have developed jamming issues on paper exit has anyone away round this
  • bojans
    • 1313
    If paper has wave shape try to increase spring tension on exit pressure rollers. Jamming could also be caused by dirty drum/corona. Clean it.
    Cheers
    • sharphead
      • Aug 2009
      • 285
      reduced spring tension done the trick
      • Northwestservice
        • Jan 2011
        • 140
        clean the exit rollers with solvent that will fix the warp and the jamming
        • bojans
          • 1313
          Yes, I forgot to mention, sometimes you have to reduce instead of increase tension. I'm glad to hear that you solve your problem.
          Cheers
          • Gift
            • Mar 2011
            • 2459
            There's also a modification available with new designed exit rollers. If you don't want to invest money it's also possible to clean the rollers but it probably won't last very long. Another trick is to set the paper sort to "thick" - the process speed is a lot reduced and that helps avoid jamming as well.
