mfc8860dn partial light prints
  • digicor
    • Jul 2008
    • 1153
    this machine has a new drum/toner installed and printed fine for about two days and now its printing light on one side of the page? Its pretty new, any suggestions? the text does not rub off so i dont think its the fuser, but im not sure.
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1250
    Re: mfc8860dn partial light prints
    Did you clean the interior of the mfc well prior to installing new parts or just installed the new drum unit? Did you use generic or oem drum and toner.......We have had trouble with Dr520 generic drum units. Those are good little machines and not much trouble out of them when using oem parts.
    • digicor
      • Jul 2008
      • 1153
      yes it was a generic drum unit
      i guess this is the prob,
      thanks
        • 22999
        Inside the housing that holds the toner cartridge, there are two spring loaded levers that press the toner cartridge to the front, up against the drum. I've noticed on several aftermarket drum units that one or both of the springs and levers is missing. It's really poor developing since one side of the mag roller is further from the drum than the other. If you catch it before you throw away the previous cartridge, you can scavenge the missing parts. =^..^=
        • Nelo
          There could be moist or dust build up on the laser glass located on the upper part of the drum and toner compartment try cleaning that glass with a clean rag also try cleaning the HV board contacts and toner / drum contacts.
          • JustManuals
            • Jan 2006
            • 9838
            Paul@justmanuals.com
            • good
              • Sep 2012
              • 51
              This is a case of poor quality toner and drum. Always use OEM to avoid this kind of problem.
