Brother MFC 8460 reset ??
  • Lotar
    • 76
    Greetings everyone,
    I have a brother MFC 8460, I have done a refurb on it, drum, fuser, LSU, PF, and HAVE reset all the counters for these items, But I want to reset the MAIN Total page counter back to zero, has anyone done this that can help me ?
    thank you.
  • JustManuals
    • Jan 2006
    • 9838
    Re: Brother MFC 8460 reset ??
    Not likely.
    • rh112
      • Dec 2007
      • 51
      Have a 2007 Toyota I did a refurb on need info to reset the mileage
      If I do get mileage reset would you buy it
      • fixitfast
        • Nov 2009
        • 21
        Originally posted by lotar
        greetings everyone,
        i have a brother mfc 8460, i have done a refurb on it, drum, fuser, lsu, pf, and have reset all the counters for these items, but i want to reset the main total page counter back to zero, has anyone done this that can help me ?
        Thank you.
        if you do a parameter initial on it i think it clears all counters and all setting back to factory out of the box. Menu 2864 (service mode) followed by 01 for initial.
          • 23006
          Silly man. There is no reason to reset the total count. If you're that concerned about counts, do some simple math. For example:
          current count - last count = prints in between
          More likely you're trying to sell your $300 tabletop MFP for a new price. If you had used some of that simple math you would see that you spent twice that amount to rebuild it. =^..^=
          • fixitfast
            • Nov 2009
            • 21
            Yeah Thats only if he used "genuine" parts. We do have alternatives now that often work better.
            • fixitfast
              • Nov 2009
              • 21
              And at 1/10th the price!
              • Lotar
                • 76
                Very true, I rebuild the DR400 and use compatable toners, and it works very well.
                • Lotar
                  • 76
                  I tried this, but it did not reset the page count, or the other total counters for print,copy,fax.
                  still looking for procedure, any helpwould be greatly appriciated.
                  thank you very much.a
                  • Lotar
                    • 76
                    I do not know the procedure, perhaps a forum for auto repair would better serve for the assistance you seek.
                    I am also not in the market for a vehicle at this time.
                    thank you.
                    • JustManuals
                      • Jan 2006
                      • 9838
                      thank you.
                      You're a dickhead.
                      • rh112
                        • Dec 2007
                        • 51
                        Just used the auto as example
                        How would you like to own something without a true known of the counter readings
