Brother MFC-8950DW Paper Jam Issue
  • tech28
    • Jun 2013
    • 434
    Re: Brother MFC-8950DW Paper Jam Issue
    I have that problem with the older Brother MFC 2100/2700, going to the extent of replacing the registration sensor(not easy and time consuming) still had the problem, changed main pwb, took care of problem. Had that a few years back on a couple of those older models. Just another thought that came to mind.
    • Printerdude
      • May 2015
      • 119
      Of the two sensor flag inside the machine, one of them is the registration sensor flag. Since both flag detected a paper jam error, we now know the sensor are working. Yes, I meant either the metal guide or plastic fins. Make sure they are clean and not broken.
      • Natebond
        • Feb 2011
        • 16
        I wiped down the metal guide and plastic fins. Everything appeared in good shape. I have included some pictures for reference.
        • Elmtech
          • Nov 2013
          • 155
          #19
          Your best bet if toner was blown through the machine is to pull it apart and clean all the sensors, hv contacts and rollers. Also when you run the sensor test move the sensor flags by hand to see if the state changes. The service manual tells where the sensors are.in the machine and how to check each one manually.
          • Natebond
            • Feb 2011
            • 16
            #20
            Elmtech, sorry for the all of the questions. Should I remove the ADF and top tray to clean the inside? I've never needed to disassemble a printer to do a cleaning like this so I am uncertain how far I should disassemble it. What do you mean by hv contacts?
              • 23009
              #21
              Now, after the compressor? Yes.
              Blowing toner around in an enclosed area is unproductive at best, and can re-locate toner into optical sensors, just like your machine. I use an eyelash wand (without the black sticky stuff) to clean the small cavities in the photointerrupters. Are you familiar with the operation of photointerrupters? There is an LED light source shining through a small slit, through another small slit to the receiver. The flag breaks the light beam ... or not. It's very easy to get toner or dust trapped in those slits. Using air can blow that toner into the next sensor.
              How far should you disassemble? Far enough to properly clean the sensors. Also make sure the all the flags are intact, and return springs in place, and the flags don't stick. How many sensors could there be? 3? Maybe 4 at most? Look in the manual. =^..^=
              • chinxxx
                • Jun 2015
                • 35
                #22
                Thanks, in advance, for any info.
                Very interesting. thanks for sharing.
                ไฮไลท์บอล คู่เด็ดเมื่อคืน ทุกคู่ ทุกแมต ได้ที่นี่ ไฮไลท์ฟุตบอลเมื่อคืน
                • Natebond
                  • Feb 2011
                  • 16
                  #23
                  I wanted to update everyone on what worked for me to fix the printer. The test drum that I had ordered during our on going discussion arrived before I fully disassembled the printer to clean the front sensors. I was actually in the process of disassembly when my friendly UPS guy arrived with the drum. I had cleaned the back/exit sensor, though that did not appear to fix the issue. Once I installed the new drum the printer immediately worked flawlessly. They had been using a 3rd party drum in the printer. I also used a 3rd party drum as well. It's possible that when the toner was blown it gummed up a gear in the drum. In either case I would like to thank all of you for your suggestions. This forum is as always an awesome place to go for printer advice! Thank you again!
                    • 23009
                    #24
                    Congratulations on your success. =^..^=
                    • tk55
                      • Jul 2015
                      • 5
                      #25
                      I work on Brother printers and faxes alot. From my experience, if the problem was with the drum and happened after you used compress air on it, my best guess is contamination of the charge unit causing electrical arcing. In the early days, when arcing occurs, it causes the machine to throw up all kind of strange errors, mainly paper jam and the machine just stop abruptly. The newer machines would also give you drum error message. I see them all the time especially when using 3rd party toner.
                      • Printerdude
                        • May 2015
                        • 119
                        #26
                        I did mention earlier in the post it could be the toner or drum cartridge. Your reply was "the drum and toner was worked before the compressed air cleaning" I didn't catch that phrase earlier, but everything worked before the compressed air cleaning, so why would the toner and drum be excluded from trouble shooting, especially a third party product of all things? Happy to hear you solved this issue and thank you for posting it!
                        • jermaine
                          • Sep 2015
                          • 13
                          #27
                          did you try replacing the fuser unit?? we had that kind of problem here, like blurry print, or sometimes jam rear, or then jam duplex. so we changed the fuser unit and everything is working good. the fuser unit is the most common problem in those type of machines
