hp color lj CM6030 MFP
  • Orion2010
    • Jun 2015
    • 176
    hello to all,
    i have a problem with my copier machine hp color lj CM6030 MFP. when i print with color the document its ok IMG_1238.JPG but when i make copy the color of document does not appear good IMG_1239.JPG. Do you have any idea ?
    thanks
  • Iowatech
    Not a service manager
    • 3930
    Re: hp color lj CM6030 MFP
    It would be useful if you would let us know what you have already tried. Otherwise we might waste your time telling you to do those things again. You already have to deal with the irritation of a machine that is not working as well as it should, and I for one have no desire to irritate you further in that fashion if I can help it.
    Thanks.
      • 23010
      The images you attached are very small. I cannot make anything of them. Can you try printing something like this?:
      • subaro
        • Oct 2010
        • 1274
        Did you calibrate the scanner ?. see page 130 of the service manual.
        Before calibrating the scanner, print the calibration target.
        1. Place letter- or A4-size paper in tray 1, and adjust the side guides.
        2. On the control-panel Home screen, scroll to and touch Administration.
        3. Touch Troubleshooting.
        4. Touch Calibrate Scanner.
        5. Touch Calibrate to print the first pass of the calibration target.
        6. Place the first pass of the calibration target face-down in tray 1 so that the arrows are facing into
        the product.
        7. Touch Start to print the second pass. The final calibration target must look like the following figur
        • theengel
          • Nov 2011
          • 1784
          Yeah, I would go through the calibrations, and then start by replacing Q3938-67901.
          • lplandin
            • Jan 2016
            • 28
            Originally posted by Orion2010
            hello to all,
            i have a problem with my copier machine hp color lj CM6030 MFP. when i print with color the document its ok [ATTACH=CONFIG]31402[/ATTACH] but when i make copy the color of document does not appear good [ATTACH=CONFIG]31403[/ATTACH]. Do you have any idea ?
            thanks
            print out your troubleshooting pages to see if you have defective cartridges.
