Hp lj P3005
  • Orion2010
    • Jun 2015
    • 176
    Hp lj P3005
    Hello to all,
    i have problem with hp lj p3005, I even change the toner but the problem still appear! Look in photo
  • 1stcavvet
    • Apr 2015
    • 231
    Re: Hp lj P3005
    check the grounding of the cartridge, on the left side, weird confusion of parts there, take off the left cover, you'll probably see whats not touching mash it with your finger and print, you might see what's not making contact with the frame. GOOD LUCK
    • Orion2010
      • Jun 2015
      • 176
      Re: Hp lj P3005
      But toner work well in other printer i test it
        • 22999
        Re: Hp lj P3005
        Right. Mr. cavvett is suggesting that the problem is with high voltage contacts in the side frame. Personally I'm leaning toward the laser unit. =^..^=
        • 1stcavvet
          • Apr 2015
          • 231
          Re: Hp lj P3005
          yeah, the toner contacts inside the left side frame of the machine, when you install the toner you can see the mechinism go in and out when it closes against the side frame it's not good contact. I think a bad or dirty laser would have blanks or dark black bars on good white places not smeary grays
          • tonerjockey
            • Apr 2014
            • 567
            Re: Hp lj P3005
            yeah, the toner contacts inside the left side frame of the machine, when you install the toner you can see the mechanism go in and out when it closes against the side frame it's not good contact. I think a bad or dirty laser would have blanks or dark black bars on good white places not smeary grays
            this page is acting quarky. yes, we look inside the printers all the time. but when we need to look at the metal spring loaded contacts, we/ I dont look closely. i recently also had a similar issue. i kept telling my self the contact was good. after 4 attempts to decide if what i was looking at was right, there it was. pull the toner out. now inside the printer to the left of the sponge transfer roller, there is several silver metal wires, like a large paper clip wire. move them back and forth. mine might have been on a 4250?, but should be similar. there is a plastic hook that holds the wire from flopping out. either it can break, or the silver metal wire can flop over and now it isnt in the fully up position. now when the toner is inserted, that spring wire never actually hits the toner contact. this might be the problem. good luck, Jim
            • lplandin
              • Jan 2016
              • 28
              Re: Hp lj P3005
              Hello to all,
              looks like defective toner cartridge
