designjet Z3200 carriage Part #
  • theengel
    • Nov 2011
    • 1784
    In the manual, I see a lot of different part numbers for the carriages between the Z2100, Z3100, Z3200, etc.,.
    I'm working on a 24" Z3200, and the part number for that carriage is Q6718-67012.
    Someone's got part #Q6718-60004 listed on ebay for fitting all the above. Will this work for the Z3200?
  • Kiran Otter
    • Dec 2013
    • 1115
    Re: designjet Z3200 carriage Part #
    Q6718-67012 was replaced by Q6718-67032 when they changed the trailing cable design; now the carriage and trailing cable come together. $1357.
    I don't know what a Q6718-60004 is; they probably took some sub-assembly part number off the carriage for the listing. If it's the listing I found (there only seems to be one) it appears to be the carriage with the trailing cable, pulled from a machine. You might luck out with that.
    Kiran
