HP Designjet T1100 carriage clipping the paper
  • tibbs
    • Aug 2008
    • 225
    Hello I have an issue with the design jet T1100 when printing the carriage clips the side of the paper.
    When the paper is new and flat it clips the side, If I would reuse the paper to print on the other side it will clip the paper and create a jam.
    Am not sure why this is happening, can anyone help.
    Thanks.
  • Kiran Otter
    • Dec 2013
    • 1107
    Re: HP Designjet T1100 carriage clipping the paper
    Are you using roll-fed paper, or cut sheets of paper?
    Has the carriage ever been removed? There is a bushing in the back of the carriage that tilts it slightly up/back, and it's very easy to break the bushing when installing the carriage assembly. It looks like this:
    See the attached PDF.
    Kiran
    • tibbs
      • Aug 2008
      • 225
      Thanks Kiran , I changed the belt a few weeks ago and the bushing came out and got broken so I stuck it back.
      I will order a new on today.
      Thanks again.
      • Lance15
        • Jun 2015
        • 1086
        Replacing my first belt on the T1100, I did the same thing. It's one of those "gotchas". I learned my lesson. Always very careful now.
