HP office jet pro 8600 "print or ink system error" they tried pulling inks
  • tonerjockey
    • Apr 2014
    • 567
    Hi, on many desk jet type machines, when we get a problem about ink, and change them and still have the same problem, is usually not a justifiable repair. does anyone know what might be causing this? besides a lengthy job and expensive unavailable parts? any help would be appreciated. thank you, Jim
  • Lance15
    • Jun 2015
    • 1089
    Re: HP office jet pro 8600 "print or ink system error" they tried pulling inks
    On the units that do not have a user-replaceable printhead, no. Just a lengthy and expensive job with no available parts.
    The 8600, however, does have a user-replaceable printhead. I've drop-shipped a couple to customers.
    • tonerjockey
      • Apr 2014
      • 567
      thank you for the reminder. any way to verify if that is the cause before buying it? thanks Jim. i think they have the same printer in another shop. i will have them try that in the meantime. have a nice day Lance.
      • subaro
        • Oct 2010
        • 1274
        With inkjets, most just replace the print cartrige and heads, but the waste ink hoses and pads gets clogged and must be cleaned. It's a messy job, but has to be done if ink build up on the pads is excessive.
        • tonerjockey
          • Apr 2014
          • 567
          Originally posted by subaro
          With inkjets, most just replace the print cartridge and heads, but the waste ink hoses and pads gets clogged and must be cleaned. It's a messy job, but has to be done if ink build up on the pads is excessive.
          thanks for the video. the machine in question isn't that single bar printer. but it was good info so i know how to actually open and find the print heads in that style. i only had one of these a year or so ago, and it had some catastrophic print error and my vendors said it wasn't worth fixing. it seems that HP wants to support them like the old style ink jets. only a few parts, and only for a year. turn and burn baby. thank you very much, Jim
          • subaro
            • Oct 2010
            • 1274
            ok , then see the one below. The idea is to get the waste ink to flow or the print heads will get clogged as you are saying. I usually opens up the machine and do the surgical there. In this video, he does it by syringes. but that does not take care of the ink on the pads. I do not know this machine and i have stopped working on inkjets a long time ago, so not sure if the pad cleaning system still applies. Simple green diluted 10-1 is very good for cleaning injets. It' all in you tube, a tech's friend sometime.
            • Lance15
              • Jun 2015
              • 1089
              Most of the time, if there's an image quality issue, it going to be the printhead.
              On models with non-removable heads, there is usually a built-in cleaning procedure that can be run to try and flush the heads out. Beyond that, though, it's trash.
              I've watched that video about manually cleaning the 8600 printhead. You may do all that work, end up with ink all over the place and still end up with quality issues.
              Just buy a new printhead if you still love the printer. Part number CR322A - $145 from the HP Parts Store the last time I purchased one for a customer.
              • subaro
                • Oct 2010
                • 1274
                [QUOTE=Lance15;517165]Most of the time, if there's an image quality issue, it going to be the printhead.
                Just buy a new printhead if you still love the printer. Part number CR322A - $145 from the HP Parts Store the last time I purchased one for a customer.[/QU
                The way the guy cleaned the printhead in the video is a quick fix method and yes it could be disaster if the pads become saturated with the fluid and start to leak and run under the unit.
                Let's say your printhead is good and the end of the hose where the waste ink disposes to the waste pad is blocked, then you can replace printheads from now till christmas and you will have problems. I have seen many of these types of printers go to the trash or money wasted on printheads because the waste system was not serviced properly. At the same time, clean the encoder and clean and lube the carriage shaft. and the paper path.
                you have to remove the covers check and clean the head cleaning station, the rubber, the cleaning hose and if the pads are gunked up, remove, wash and put back in slightly damp. all this is messy and your tools and every thing that touches the ink has to be cleaned soon after. I do them once in a blue moon for family or close ones. Or just replace the whole machine.
